Discuss Cutting Stainless steel trims in the Australia Tiling Forum area at TilersForums.com.
Tile Fix Direct
TF Official Sponsor
Points
733
Aldershot
When cutting and mitring stainless trims I am struggling to make a good, accurate and scratch free cut. How do others achieve a decent finish?
Waluigi
Are you using a mitre block and fine toothed hacksaw?
If so then you’ll need to file back the exposed cut edge very slightly with a fine flat file.
Bathfix Bob
Points
588
I use a standard £5 mini mitre block and cut the trim upside down, I also use an old heavy Eclipse hack saw with a good blade. Lightweight new ones are rubbish.
One Day
A Quansol mitre block and good quality saw and blade.
Smooth off with file and maybe a diamond hand pad.
Andy Allen
Points
1,318
Gloucester
This is the best mitre block I've bought..
It has a Grove in it to fit the flange of the trim in so it doesn't slip, and I've screwed mine to a piece of ply so you can get a better grip of it
Waluigi
I use a cheap wooden mitre block from Toolstation and a hand file. Don’t bother using my diamond pads. Never thought about using them TBH
I’m guessing a 120 or 200 grit would be ok. Get it from AliExpress (surprise surprise :tearsofjoy:)
Reply to Cutting Stainless steel trims in the Australia Tiling Forum area at TilersForums.com
