Discuss can we fix ditra mat down with a gypson adhesive ? in the Canada Tile Advice area at TilersForums.com.
dexo
Points
46
luton
we have 80 m floor to tile which has been layed for 4 weeks now and it is a gyvlon screed type it has underfloor heating which has been on for 10 days now
we would like to stick a ditra mat down to screed with a gypson based adhesive has anybody used this method as we r getting mixed comments on this help
I
Ian
4 weeks isn't long enough IMO, have you had the screed moisture tested? I have fixed Dural Ci+ using Creative Impressions GBTA, and it was very successful. It's the method I'd use if and when I tile to a gypsum screed in the future.
bugs183
Hi Dexo.
You will get mixed views on this Dexo, as there are many opinions about the methods of fixing to these screeds, but the lads here are all trying to get the answers.
Creative impressions GBTA is working well as an adhesive for gypsum floors, but Schluter are saying they prefer cementitious adhesives to fix Ditra.
As Bri says, don't for one minute think that having the heating on will mean the screed is dry enough. You have to moisture test as these screeds are way more sensitive to residual moisture than a traditional sand and cement screed.
Peter
Is it a possibility to use vinyl adhesive for sticking the Ditra down in these circumstances?
bugs183
Yes, this is another method that is being used.
Obviously the floor will need moisture testing, then sanding and vacuuming, before application.
Pebbs
I have done a lot of meterage on these screeds and have always used ditra matting, but that is my preferred choice and I will continue to specifiy it and install it for the foreseeable future. However I would never use anything else but Ardex AF200, again it comes down to personal choice.
Pebbs
nybor62
Points
1,083
rotherham
is it ok on gyvlon lynn ive used it on timber floors , great stuff, if it work well on gyvlon , then that would be my method of fixing
what i will say fixing ditra with floor adhesive , you can manage on you own , with the af200 , its a 2 man job esp if it s long runs ,
sticks like $ hit to a blanket
Pebbs
As long as the gyvlon has been tested and passed, we then sand it and prime it. I have never had a problem with AF200 and ditra, over these screeds. There are price implications for using the AF200, its never been 'cheap' but there would be bigger implications if the floor failed.
Pebbs
Reply to can we fix ditra mat down with a gypson adhesive ? in the Canada Tile Advice area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
