Discuss Best all round blade for grinder? in the Australia Tiling Forum area at TilersForums.com.
Sean Kelly
1,068
Ruislip
Found this a good blade for porcelain http://www.atsdiamondtools.co.uk/node/33
Alan from ATS sent me 2 of the above blades by mistake. They are excellent in the angle grinder, as good as a wet cut. Superb value for money. Thanks Alan for sending me my original blade order too.
Honestly Icctiing, save your money and just go with ATS. I've spent so much money on CK850's, but now only buy from ATS.
Just Rizzle
marcrist for me tend to replace them every 6 weeks or so never let them get to low as the quality of cut reduces as i use a 110 grinder i cool them down by holding a damp sponge against the blade much faster and easier than a wet table cutter also reduces the dust, my grinder is the best tool in my box. can cut holes as good as a hole cutter with a ball hammer years of practice. lol
Stef
might be an obvious question but how are the ats blades so cheap? In comparison with marcrist or monolit etc??
Because Alan sells them direct with no middle men to take a chunk of your cash.
Don't get me wrong the pro-gres is a cracking blade & far superior than a marcrist blade but the ATS blades are up there with the pro-gres.
Even the cores from ATS are the best I have used & are pennies compared to some others.
I tested the dry cores for them & they are a serious bit of kit..
Reply to Best all round blade for grinder? in the Australia Tiling Forum area at TilersForums.com
Good morning all. After a little advice. I'll post pictures a bit later. However.... The homeowner of the property I'm working on has just come to me and asked if anything can be done about...
  • Sticky
  • Question
