Currently reading:
Advice needed grout cracked
Discuss Advice needed grout cracked in the Tile Adhesive / Grout Advice area at TilersForums.com.
John Benton
1,138
Leeds
Soŕry WalLuigi, no.
Any of you guys used the Mapei colour match sealant in the corners and can you get a good finish/match with grout?
Yep pretty good colour match
Time's Ran Out
Now here’s an question!
What did you all do before the colour matched silicone was available?
You see in my opinion the builder did what we used to do - grout the corner and go over the dry grout with a clear or white silicone.
The bigger issue here is why is it cracking so much that it’s become a major concern?
As a tiler, I silicone the corner, fix the tiles, grout, then silicone the tile face again. Always have always will!
Don't be so quick to judge the builder. Silicone is great unless you happen to have RIW tilesafe membrane behind. I would normally leave the internal corner joint free of grout then silicone knowing the silicone would bite nicely into the gap however CCL Wetrooms advise if you use silicone then warranty will be void. Builder may have been following instructions. RIW also advise the same. And that's why I won't use the bitumen style membrane
Reply to Advice needed grout cracked in the Tile Adhesive / Grout Advice area at TilersForums.com
Hello, I'm just a home owner who doesn't have much experience with tiling but I'm looking for advice on fixing a few problems that a professional left me with. He of course has not responded to...
I've recently bought Johnson 'Orkney Stone' ceramic floor tiles from B&Q. Paid to have them professionally laid. At the time I asked if they needed sealing. The tiler told me since they were...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
