Discuss Cutting advise for 38mm Yorkstone in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
38
London
Hi all, just wanted to ask for some advice please as to best option for cutting 38mm Buff Yorkstone steps and slabs.
I will be cutting 1500mm steps length ways for the risers along with 600x600 slabs.
I was looking at hiring a Flex CS60 with rails but not sure if that will do the job or if there is a better option, I would like to make as least mess as possible if there such a option, also there isn’t much space on site.
Many thanks in advance!
These are the steps:
38
London
If its a one off job , hire a sthil saw.
Hi, thanks for the reply, we do have one but am concerned won’t be able to get that straight cuts along the steps as they are 130cm long hence I thought having a guide rail with the Flex saw would be a better option?
Dave
Subscribed
1,000,000
Co.Durham
Cuts edges would go to the back. Or are both edges on show. ?
Do you have any pics of your project?
38
London
Hi, back and one side are covered but right side will be visible.
38
London
What’s your intentions with the handrail?
Ok i see its more bespoke work entailed. A rail saw and diamond pads required
Hi, planning to remove the rail and modify it with help of a welder to make attached on the side of the stairway as don’t want to make holes in the steps.
Reply to Cutting advise for 38mm Yorkstone in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
