Discuss Would you grout these split face porcelain tiles? in the America Tile Forum area at TilersForums.com.
Photo attached..
Reply to Would you grout these split face porcelain tiles? in the America Tile Forum area at TilersForums.com
  • Question
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
  • Question
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have sliding shower doors. The tiles are 600x1200 blue/grey onyx style which I would like to look like one...
  • Question
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are porcelain. I’ve just got to the end of my bag of Mapei flexible rapid set tile adhesive (powdered)...
  • Question
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
  • Question
