Discuss Minimum Depth XPS Backboard for Flooring? in the America Tile Forum area at TilersForums.com.
Kevbos
443
London, UK
Evening all,
Hopefully a very simple question here, can anyone advise whether 6mm XPS tile backerboard would be suitable for laying over a timber subfloor (floorboards) to tile over within a bathroom? Or should be I be looking at say 10mm instead?
Thanks for your assistance,
Russ
No it's not good enough nearly !!
Kevbos
443
London, UK
Can you suggest what would be more suitable please?
Some on here won't like this !but I'd suggest just taking floor boards up and strengthening joists with some extra noggins, then use Marine or high grade ply to at least 30mm in thickness , I usually put 18mm down screwed to joists alot of screws , then over board with at least 12mm ply again !screwing at 6 inch centres or less , prime ply with sbr , lay durable decoupling membrane , then tile
Kevbos
443
London, UK
An error on my original post (now amended). The existing subfloor is 18mm structural ply and not floorboards as originally stated, the original floorboards were knackered from being tiled onto historically so I opted to remove the lot and renew in ply.
I know some tilers will disagree !! Loving a cement board etc , but I was a victorian tiler for many years !not one failed floor because I done it properly
Reply to Minimum Depth XPS Backboard for Flooring? in the America Tile Forum area at TilersForums.com
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm...
