Discuss 1st time tiling floor advice in the America Tile Forum area at TilersForums.com.
Hi iv done few small tile jobs on walls 1st time tiling a floor about 33 yards, im going to be using 450x450 8mm thick ceramic tiles just have few questions,
what size notched trowel should i use?
can i use 1.5mm spacer?
is a washboy worth buying?
Hi I have a Rubi Washboy and I honestly can say I wouldn’t be with out it
Reply to 1st time tiling floor advice in the America Tile Forum area at TilersForums.com
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
  • Question
  • Sticky
  • Question
