Currently reading:
Corner set out
Discuss Corner set out in the Canada Tile Advice area at TilersForums.com.
Dave
Subscribed
389,894
1,000,000
Co.Durham
What's your tiling question? Pictures can be added.
Tiling into a corner. Full tile next to a cut tile or 2 cut tiles next to each other to form the corner with 2 full tiles together above ?
I have seen pics online of both. Is there a right way ?
You want it to look as uniform as possible and setting away from a full tile isn’t usual practice incase the wall runs out of plumb.
No try and set it out for good sized cuts , not full tiles.
Sorry I haven't explained it fully . That is my corner, I either have a large tile meeting a large tile or a large tile on bottom meeting a small cut tile.
Dave
Subscribed
389,894
1,000,000
Co.Durham
Ah right. Pics always help 😁 , check if the wall is plumb that you’ve already tiled. If out then set the full tile at worst out of plumb , top or bottom and draw a vertical line from that , trim tiles as you so there is no gaps. Hope that helps.
Reply to Corner set out in the Canada Tile Advice area at TilersForums.com
  • Sticky
