Currently reading:
New build underfloor heating and tile installation
Discuss New build underfloor heating and tile installation in the Canada Tile Advice area at TilersForums.com.
Hi
I am want to get my new build kitchen floor, hallway and utility tilled. I am plaining on having Underfloor heating installed in my kitchen an have bought a mat based underfloor heating system with insulation boards(Xp pro insulation board by prowarm) . I got quotations form several tilers. with the following options
1.Install crack matting to Hallway, Utility , and use the insulation board on kitchen)
2 Install Crack matting in all three areas. (Adhesive on crack matting Insulation board and then Tiles).
3.Not use crack matting use a levelling compound(fibre based and use a high quality bonding agent).
Please Advice. I have attached the pictures.
Nal
Dave
Subscribed
389,894
1,000,000
Co.Durham
Thanks Rae does the insulation bords go before the crack matting or after the matting?
The screed needs insulation before tiling , use a cement faced insulation board , they can uncouple the floor and insulate at the same time.
if you don’t insulate it’ll cost a fortune to run.
N
Nalaka Vithanage
Sorry Rae I have bought xp-pro insulation board by pro warm will that do or shall I just get rid of them and buy New ones which are ciment based. Thanks for answering
Reply to New build underfloor heating and tile installation in the Canada Tile Advice area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which is very thick concrete. He wants electric underfloor heating but I'm concerned he'll lose too much...
