Discuss Why do you guys that regularly mitre in the Tiling Tools area at TilersForums.com.
No, they don’t need a machine edge, a scored line is fine.I do the odd job where it’s fully mitred and never used a specific machine. Do these machines rely on a perfectly machined edge for the mitre to come out well as the machine has to be dragged along the edge? If so then that’s a reason to not use the machine as most mitres I do are on a scored and snapped cut.
Fair enough .Few reasons Jerry tbh.
Firstly, personally having tried a number of purpose built machines, and in fact owned them, they’re not up to the standard I need.
They’d work well with Schluters Finec trim, or somewhere where a much larger joint is used on the mitre, you don’t need to get too close to the leading edge.
In fact I’ve just finished this, 5 mins ago.
Machines are too heavy and have a lot of vibration, causing the front to sometimes break out.
That edge is less than 1mm, even if photo doesn’t do it justice
Those machines that run on rails, do exactly that, so for example, if you place the rail on the piece and it does not follow the face of the tile exactly, the machine just carries on regardless, following the line of the rail.
This means that if the tile dips in the middle for instance, the cutting or grinding blade will come up thro the front and you won’t even feel it happen. You’ll just see it after the machine passes over it.
By hand, the tools will give feedback and you’ll adjust the angle/line/pressure accordingly.
Machines can’t do that.
And I’m also a firm believer that you need to be able to reach a high standard by hand and eye first, before you even attempt to use a machine.
How’s that for a reason?
One expensive toilet roll holder.
Just ease off the leading edge with a diamond pad first so that when you mitre, you shouldn’t get tiny chips on the edge.
Tile dependant sometimes, and practice of course.
Fair enough .
Hand job then
I agree with the what suits you best , I've had cutters that I've given away because I think they're rubbish but it's obviously they didn't suit me , it just that some people come up with an answer for something that isn't a great product , so any advice from someone like yourself that does this on a regular basics is greatly appreciated even though it is only an opinion
It’s like anything Jerry, why do I prefer a sigma slide cutter when others prefer Rubi/Montolit.
Just do what suits you best, and forget everyone else mate.
There aren’t any rules.
It’s not that they rely on it for any technical reason.A scored line that has been neatened up then? These machines do rely on the edge being reasonable flat then? I’ve never used one or know how they’re used but might take a look at some videos
Reply to Why do you guys that regularly mitre in the Tiling Tools area at TilersForums.com
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
