Currently reading:
Grout haze over walls and floor.
Discuss Grout haze over walls and floor. in the Canada Tile Advice area at TilersForums.com.
On one
If it is obvious that grout haze is going to be a problem(Probably is by the time you have read this) I would just leave the floor alone. The more you go over it,the more grout you will wash out of the joints.
Leave the floor until tomorrow morning,give Lithofin Tech Dept a ring and they will sort you out for what you need to do.
This info is very dependant on your situation though.......walls,floors,risk of acid etching surrounding fittings,type of grout???? and so on. So a bit more info required.
Hate to be negative, but I had this issue with porcelain floor tiles.
Tiles were lightish wood affect, used a "Tobacco" colour grout. Grouted the 4mx4m room and then cleaned off. The grout left a haze which turned out to be a stain.
Hit it with all I could plus advice and the room is the same, no better.
Faced with the rest house to do on that level.
After grouting 1mm joints the grout was removed much quicker and frequently. It worked and proved the grout was staining.
Reply to Grout haze over walls and floor. in the Canada Tile Advice area at TilersForums.com
Hello, after tiling the kitchen area I did grouting but I am not happy with the results. The grout lines are too bright, almost white. Although I used almost dry sponge to wipe off the excess...
