Discuss Dressing beswick limestone slab.... in the DIY Tiling Forum area at TilersForums.com.
Andy Allen
1,318
Gloucester
Better used on a polisher or variable speed grinder.
You'd have no control at 10,000 rpm+.
I always explain to people that the clue is in the name - a grinder is great for grinding (and cutting) , if you want to polish you need a polisher.
As this is a one off job and I just need to dress 2 curves, would the hand polishing pads work ?
Concrete guy
Really it all depends what finish you want.
Wet and dry paper will work for a one off.
It's worth investing in a variable speed machine as it really opens up what you can offer the customer, I see a lot of guys on here use the Bosch one, which looks like good value for money for a few jobs.
Reply to Dressing beswick limestone slab.... in the DIY Tiling Forum area at TilersForums.com
Good morning all. After a little advice. I'll post pictures a bit later. However.... The homeowner of the property I'm working on has just come to me and asked if anything can be done about...
  • Question
  • Question
  • Sticky
  • Question
