Discuss Dressing beswick limestone slab.... in the DIY Tiling Forum area at TilersForums.com.
Andy Allen
Points
1,318
Gloucester
Got some beswick tumbled limestone slabs to do in the new year, I have to cut a curve in some of them and dress the edge, was going to use a polishing pad from ATS what grit would you recommend for limestone.
Or anything else that I could attach to a grinder and use...
Concrete guy
Can they be used with a grinder ?
Better used on a polisher or variable speed grinder.
You'd have no control at 10,000 rpm+.
I always explain to people that the clue is in the name - a grinder is great for grinding (and cutting) , if you want to polish you need a polisher.
Andy Allen
Points
1,318
Gloucester
As this is a one off job and I just need to dress 2 curves, would the hand polishing pads work ?
Concrete guy
Really it all depends what finish you want.
Wet and dry paper will work for a one off.
It's worth investing in a variable speed machine as it really opens up what you can offer the customer, I see a lot of guys on here use the Bosch one, which looks like good value for money for a few jobs.
Reply to Dressing beswick limestone slab.... in the DIY Tiling Forum area at TilersForums.com
