Currently reading:
Floor sanding accessories
Discuss Floor sanding accessories in the Tiling Tools area at TilersForums.com.
Italy
Sorry Andy didn’t see this.
60# copper sanding disc. Don’t ask me where to get one. :)
this is in my garage
Italy
Not sure what you mean by tungsten carbide pads? Id like a durable solution, do the copper discs last a while or do they wear fast like a paper disc does
those in copper are tungsten carbide.
they last longer, but the cost is also higher.
mine does not do a good job, maybe I took a too big degree.
I prefer sandpaper, but I could be wrong I do not use it much.
H
hmtiling
Perhaps I should try some 60 grit sandpaper first and see how that goes
I've used sandpaper on fresh ones with success Andy. I've only ever had alpha hemi hydrite ones though if that makes any difference. Interestingly, I've just seen a statement from Knauf, who supply the raw material for the ones I get, that the alpha hemi ones mayhew easy screed do don't need sanding!
Concrete guy
Well, I'd take that with a pinch of salt ey.
I've come across all sorts all more so lately cement based screeds that need sanding, and if your sanding within the first couple of months they all sand pretty easily, the diamond can be over kill for them.
Take a look at Abtec Abrasives website, they stock things like silicon carbide screen meshes which are less aggressive than cup wheels but tend to be for larger machines at 225mm or 430mm.
We point people to them when they are trying to sand or polish some microtoppings that behave more like a levelling compound than a sand/cement screed.
The advantage of diamonds only kicks in when you're removing a lot of material or the floor is very dense/abrasive, or both.
H
hmtiling
I've always sanded them but am going to do a test next one I get. Primed, unprimed, sanded and primed, unsanded and umprimed. I'll fix with anhyfix as usual and post results.
If it was a screed company saying that then I'd take it with a lot of salt but can't imagine a company like knauf making a statement like that without it being factually correct. Big firms like that tend to err on the side of caution. Who knows?
Big risk as opposed to a relatively small amount of work though
Reply to Floor sanding accessories in the Tiling Tools area at TilersForums.com
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this, The property unfortunately flooded throughout. Now although I'm told it's all dry now I'm reluctant...
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
