Discuss News Montolit Tilers Tools | Montolit tiling tool news and reviews in the Tiling Tools area at TilersForums.com.
Don't want to say I told you so, but I told you so!I thought you were official tf tool tester
No problem Sam, whenever you want mate.Not 100% Sure it may need slight modification to fit. I will get one out and take a look tomorrow as i have got to leave work shortly
given that the individual concerned does not add news
no marcHave you used it Antonio?
I met Giuseppe at Trimline, he was a very pleasant and friendly guy, but still a salesman.
That said, he did replace a broken Montolit blade, and for that I have total respect.
It will be approximately £130 in U.K.
I am concerned however may be too lightweight. Sometimes I find extra weight helps.
Maybe this will work similar to regular orbital sander?
Battile is cordless tho. (that's what interests me)
1mm thick blade. A bit thinner than my go to CGX blade I’m using which is 1.3mm
Blade of 1 mm, requires use of tutorcut1mm thick blade. A bit thinner than my go to CGX blade I’m using which is 1.3mm
Some lovely tooling as usual from Montolit. I look forward to having a proper look when I get home. Some good ‘sat on the toilet’ reading.
Thanks @antonio
Reply to News Montolit Tilers Tools | Montolit tiling tool news and reviews in the Tiling Tools area at TilersForums.com
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
