Currently reading:
Tiling a concrete floor in a room that used to be outside
Discuss Tiling a concrete floor in a room that used to be outside in the Canada Tile Advice area at TilersForums.com.
Spacey
Just make sure you apply the liquid dpm to the correct thickness or it will be ineffective.
If you get more coverage than it says, it's too thin.
Or this
Tilemaster liquid DPM
Haven't seen this before but I do use superflow30 I'll look into it
Most epoxy liquid dpms are applied with an A2 notch fan trowel and then rolled with a fine roller.
This thickness is measure in microns
It shouldn't be laid to thick either
Thank you all for your responses. I have now been to see this floor. It is basically a nice level slab. It has carpet tiles over it at the moment which the customer wants to be replaced with tiles. The carpet tiles are slightly damp underneath. I think the concrete will dry out when they are removed. No damp course under the slab but in no way could you consider it to be 'wet'. What do you think if I used a swimming pool type addy and grout?
Italy
full
full
I used it in this work.
Reply to Tiling a concrete floor in a room that used to be outside in the Canada Tile Advice area at TilersForums.com
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this, The property unfortunately flooded throughout. Now although I'm told it's all dry now I'm reluctant...
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
