Discuss Laser Level Recommendations in the Australia Tiling Forum area at TilersForums.com.
Reply to Laser Level Recommendations in the Australia Tiling Forum area at TilersForums.com
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
  • Question
Hi all. Just wanting some advice and wondering what the pros in here are using nowadays for cutting large format porc? Ive been relatively lucky up until recently and been able to cut most of...
  • Question
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
