Currently reading:
Use of laser level
Discuss Use of laser level in the Canada Tile Advice area at TilersForums.com.
L
lasors
Hello all,
This may be a silly question but, if I use a laser level to give a starting level on a wall, can I just apply adhesive and then position the tile on the level and expect it to stay there on the wall without batten support? Tiles are 400x300 with Keraflex adhesive.
Finding a perfectly straight piece of timber I find to be impossible, and I don't believe my spirit level is accurate enough to tile all the way around a bathroom. I'm therefore considering purchasing a laser if it really will make things that much easier, even if it won't get used that much.
What's the trick here?
Thanks again
L
lasors
For tile battens I go to B&Q, buy a sheet of 18mm MDF (2.4m x 1.2m) and get them to cut it into strips of about 65mm, gives you a nice straight piece of timber to tile off :thumbsup:
I've done this, with 18mm ply. Working a treat so far, did one wall today and it was level all the way up! First time using cementitious adhesive as well. Used mapei P9, quite easy to use and I like the fact it has a long working time, means I can pootle along at my own pace.
Thanks for the tips.
Reply to Use of laser level in the Canada Tile Advice area at TilersForums.com
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
