Discuss Slc Method, My Way - How To Use Self Levelling Compound Properly in the Canada Tile Advice area at TilersForums.com.
i use 150 x 150 white wall tiles cut into 50 mm strips and and use these for level screeds when latexing like your method Phil
I always seem to pull dips in to my work when i run screed channels and am more comfortable using wooden laths when screeding but i only screed 2-3 jobs a year and tend to drop lay when fixing with sand and cement do you have any tips to stop me cutting into my level screeds when ruling off ?I have been screeding outside last week Phil with 3-1 sand and cement and waterproofer laid into a slurry of SBR & OPC , i always lay strip's of screed and then rule -off to them works great every time !, But i have never used' it for SLC , so if i need to, i will use THE PHIL HOBSON method :hurray: from now on mate thanks Dave
Once the runner or screed has set you can flood the bay with slc and fill with the help of a feather edge. hope this makes sense, and maybe helps someone.
when you're doing a sand and cement screed Dave, what do you use to screed off?, I've accrued a few various lengths of scaffold tubing over the years (straight!) and I find them superb for screeding off.I have been screeding outside last week Phil with 3-1 sand and cement and waterproofer laid into a slurry of SBR & OPC , i always lay strip's of screed and then rule -off to them works great every time !, But i have never used' it for SLC , so if i need to, i will use THE PHIL HOBSON method :hurray: from now on mate thanks Dave
Same as me , I use doorstops on top of bankers around the edge if i do a S&C screed - which hasn't been for a while - .Without the doorstop , I think if you tamp your bankers in a bit more , making them a bit more solid and try not to lean on the straight edge , also try taking a bit less off each pull.
Diggy
all in the stomach and shoulders MarkI never tamp the screed, just bring the screed about 10mm higher and push forward with an ali screed rule with a small amount of body weight on the screed rule.
Well Gary & Doug i use aluminium screed rules i bought from rafina , it's in the hand /wrist movement i would say, ruling-off then rubbing flat to consolidate the mix , i have been doing it so long that i rarely need a plastic float, just start rubbing i can see low spots and just throw a handful of compo -on, and rub with rule ! then use these screeds to fill-in between and rule down to the level of these ....... hope that helpswhen you're doing a sand and cement screed Dave, what do you use to screed off?, I've accrued a few various lengths of scaffold tubing over the years (straight!) and I find them superb for screeding off.
Out of interest , when you say fill with a feather edge , do you mean flood first , let set , then finish with the FE?
Sorry Diggy, I mean I fill each bay with slc then draw off with feather edge while still wet.
Dots - runners - semi dry - you've just lost 99% of of all viewing!
Some of the threads, comments and reactions to 30 year tilers forget that some of us had a life before tubbed adhesives.
Anyone suggesting a fire and slippers to me will get a response.
Respect to Mr Hobson.
Good thread, and I'm with it, but I wouldn't mind a bit more detail on the "dots set by laser runners made from 3-1 compo plus polymer and rapid set adhesive", if possible please?
Whats with the triangular bay Phil ? To get a way out from the corner we can't see and tie up with the step height?
Also , how quick do your runners take to set?
Cheers
Diggy
I have to wonder though...why the need for so much levelling. Surely when a client pays for a new sub floor it they should expect it to be level ??
Reply to Slc Method, My Way - How To Use Self Levelling Compound Properly in the Canada Tile Advice area at TilersForums.com
