Discuss test without haste :) I'm slow and old :( in the Tiling Tools area at TilersForums.com.
I
Italy
I wanted to share this test, without haste.
I started with sankyo, for now it's ok.
ps, purple ds diamont, is the only one that I found made in Italy.
costs 35 € in italy, 5 € more than montolit and sigma,
with similar characteristics.
norton and sankyo 25 €
I
Italy
the Italian surrendered ....
I cut a 20 tiles 60x60x2 and it was ok.
Today has surrendered be in front of a 10mm. :(
I took this bath, 60x120 florim rex.
never seen a tile so hard .... :(
with the tile cutter it was almost impossible to cut them, 1 cut every 4
it was ok. the tiles were counted, I could not afford to make mistakes.
so I decided to use the grinder, 6 diamond blades available.
the only blade that could cut a bit, was an old montolit tcs
now at the end of life and even cracked. :(
I also tried it with a sponge, nothing to do.
I gave up and bought a new tcs 115 .... amen
Ps the tcs montolit is smoking the tiles ...
first, they smoked the blades
20180524_124549.jpg 20180524_124629.jpg 20180524_124650.jpg 20180524_152815.jpg
I
Italy
then, the pink blade made in Italy
he made me turns the bales and ended up in the toolbox.
I mounted this black norton, I state that it was the first time
that I used that diamond design
and I did not convince me already before use ..
but .... after 2 days .... I changed my mind,
the blade sinks into the porcelain like
butter and with a few chips, I cross my fingers and I hope it lasts a lot of time.
we feel next week with thin porcelain cuts.
I do not go on vacation ...
Reply to test without haste :) I'm slow and old :( in the Tiling Tools area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
