Discuss asphalt substrate! in the UK Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
at 20mm deep I would think you need to be wary. You can tile into Asphalt but you would probably need to overlay it first. There are a few options for this. You could use a gypsum based levelling compound. You could use a cement SBR slurry or you could use an epoxy sealer. Most people I know who have done this (not that many to be fair as it is not a common domestic substrate) have gone for the SBR cement slurry option. I would also use an uncoupling membrane to be on the safe side and to prevent any possibility of migration of the bitumenous oils which could stain your tiles long term
Others may have other options availbe
terrygrant
SBR is a liquid much like PVA to look at but dont think you can use PVA insead as you will come unstuck (please excuse the punn :)
You mix it with neat portland cement and paint it onto the ashphelt then apply your adhesive for your tiles or decoupling membrane while it is still tacky so its fairly straight forward.
Good luck
Terry
On The Tiles (Hillingdon) Ltd
On The Tiles - Professional Tiling Service - High Quality Tiling London
Ajax123
1,213
Lincolnshire
The membrane under the asphalt on top of the sand is most likely a simple DPM. Common practice with screeds. As for the levelling compound I would suggest this simply to give you a flat level surface on which to tile. If you use the SBR/Cement Slurry you would need to use a cement based levelling compound. Go for a flexible one because the asphalt will expand and contract more than would a solid concrete fore example.
V
vosnack
I'm gonna use either slurry or levelling compound. But thanks for advice regarding compliance(not sure if correct word) of slurry with SLC(that it need to be cement base), good for the future. I'm more likely to use the slurry.
By stating go for a flexible, you meant flexible adhesive or compound? I assume you meant adhesive.
terrygrant
In my opinion the best Self Leveling compound I have ever used is Mira X-Plan. It is a polymer modified latex but what seems to make its performance superb is that it has fibre reinforcement. It can be built upto 50mm in one pour as well. However it is expensive and likley to cost around £25 per bag in small quantities but you can get down to about £15 if you a buy a palette and haggle(all ex vat)
Available from Trimline
Terry
Reply to asphalt substrate! in the UK Tiling Forum area at TilersForums.com
  • Question
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
