Discuss asphalt floor advice in the UK Tiling Forum area at TilersForums.com.
mickyc
Hi Dave,
I have been there today and had a look and seen were the floor levelling has broken up completly , the chap i spoke to stated he had done it twice and same result.
So asked for my advice , what i have gathered it is an original roof of the building and i would state that the thickness would only be a few mil & yes its roof grade asphalt.
I presume it is on concrete it is an old hotel.
Most of the job is floor levelling and timber floors going in but kitchen is to be tiled about 25 m2 / but other floors still need to be levelled.
I was wondering if you could use something like that green paint on grit compound thats used in plastering to give it a key you put it on prior to plastering for bad walls ?.
Thanks for reply mike.
Reply to asphalt floor advice in the UK Tiling Forum area at TilersForums.com
  • Question
