Discuss Indian Sandstone Picture Framing/Grout marks in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
1sandyh
hi all,
Had patio done 2 months ago by landscaping co. Slabs are Indian Sandstone ‘Raj Green’. They were varied Autumnal colours prior to grouting, browns/reds/yellows..
Problem is there is a picture frame effect in & around the grout lines. The slabs are bone dry but look wet around the edges. Some are quite big stains running into the centre of the slabs.
The raj colours also seem to have been lost, they look more grey now. Almost looks like a residue covers the slabs now? The grout used was mushroom grey so I’m wondering if it is grout residue or something else?
Sandstone was NOT sealed. Grout used was a dry brush in type.
Patio has been cleaned twice, first with washing up liquid, stiff brush. Second time with patio cleaner, stuff brush & jet wash. Still no better.
Company said it will fade. I doubt it. Would rather try to clean them up & sort it out myself so I can actually enjoy looking out on my patio!!
I really need to avoid anything harsh/acidic if possible as there is an aluminium track & glass around the perimeter of the patio. That’s another reason why I’m worried if they come back to clean it, they may ruin the ballustrade.
How do I sort this mess out? The patio is 50m2. Thanks
78747211-DCEC-42D1-9DF4-788494F12FB0.jpeg A0292F28-8AC8-483B-AFD5-CBB21415B1A1.jpeg 0A9CFF15-409F-4F1A-B51C-BB1E97A4BC28.jpeg
1sandyh
They used ultrascape flowpoint, according to the bag the area should be wetted & then grout brushed in. Which is what he did. Maybe he didn’t rinse/clean it off enough after.
I’ve asked him to come back again but I dont want him to make things worse using harsh cleaners etc or fob me off.
What is the best course of action usually with this? Will it fade/wear off eventually?
1sandyh
They definitely weren’t sealed. How on earth am I going to rectify this now? I’ve contacted the boss of the company today, sent photos & he said he’s coming round tomorrow.
What worries me, is if they didn’t use this product right then what are they going to use to remove it? He said he usually uses the ready mixed grout eg easy joint so ‘maybe there was an issue with the dry grout’. No the issue was how you used it!
Anyone have any clue how to sort this? Please don’t say replace the patio, way past that option.
Are there any products at all that will remove this?
Bill
drop @Lithofin BOB a message and he may come up with a solution (pun intended)
Blunt Tool
1sandyh
Callatiler - is that Lithofin product ok on Indian sandstone? I’ve read some horror stories tonight about using acid based products. I see it says suitable for stone but ?
So essentially he grouted the entire patio, not just the joins but the surface of the slabs themself. Honestly this patio has caused me more stress than it was worth.
My other concern is the aluminium track & glass around the perimeter of the patio. How best to protect this from being damaged from these products
Blunt Tool
Oh Jesus I’m going to be crapping myself doing this!
Just out of curiousity - what’s the difference between the lithofin cement away & the builders clean?
Should I use neat or ??
No use Lithofin and a 1 litre bottle can be diluted with 20 litres of clean water do not use neat. I would personally get a clean 10 litre bucket and add 100ml of cleaner and mix, then I would have 3 buckets of clean water beside me
Bill
They were only meant to slightly wet the joints not the slabs, then brush in dry mix and leave for a while, then the dry mix sucks the water from the bottom of the joint then just smooth using a brick jointer and brush excess dry mix away. Now I would clean slabs with a cement film cleaner
Lithofin Cement Away (1L) - https://www.tilefixdirect.com/product/LFCA1L?gclid=EAIaIQobChMIp9iojo2-3gIVZpPtCh3oeAtdEAQYAiABEgJkxfD_BwE
Ultrascape is a wet grout and is supposed to go all over the slabs too. Other products differ.
Reply to Indian Sandstone Picture Framing/Grout marks in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
