Discuss Brick Bond (Metro) advice in the DIY Tiling Forum area at TilersForums.com.
Z
Zub
Hi all,
First time tiler. Decided to tile the kitchen after a fire destroyed the old one.
I need a bit of advice as to which layout I should use for the pipe which has been boxed in.
Do I ignore the bond on the arch, split each side of the boxing into half and brick bond? Or do I continue the bond from the archway? If so, how? I've attached a few sketches below. Sketch 3 looks the most appropriate to me, however that would go against what I have on right corner.
Help!
Thanks in advance
Dan
Admin
5,040
1,323
Staffordshire, UK
Reply to Brick Bond (Metro) advice in the DIY Tiling Forum area at TilersForums.com
  • Question
