Discuss Bevelled Metro Tiles..... Trims, edges and window reveals. in the DIY Tiling Forum area at TilersForums.com.
Chris Bates
Hello,
This is the first time of posting and hope that someone can give me some advice or posing me in the right direction.
I've tiled successfully in the past and, in my opinion, done a decent job, but now face fitting bevelled tiles.
My question relates to the height of the tile trim around window reveals and edges.
My first idea was as drawing A. This allowed a thin quadrant edging and finished with a good edge next to the trim. Great so far.
Looking around I have only seen it done as B. Where the trim is at the same height as the top of the tile. This, in my opinion, looks messy as there is lots of grout around the bevel and we see a cut tile at the edge.
Then we move onto the window reveal, the quadrant trim has to be as drawing B, because of the cut tiles.
Can anyone recommend the neatest way of fitting the trim on Bevelled Metro tiles.
Chris Bates
I'd you have any wall underneath the window that you are tiling you are going to have to consider this when setting out your tiling so you can't just Tile up one side how you want without it affecting the other side of the window.
Thanks. Yes, I also have a window to consider, cooker splashback on the same wall, both of which should be symmetrical.
Chris Bates
Hello again,
I've made a start, by undertaking, the "easy" wall. This is the edge that I was concerned about. 8mm trim on the top and 10mm on the sides. I filed a 2 x 15 mm chamber on the top of the 10mm trim to match the profile of the tile.
Does anyone have a preference of how to lay the first row of tiles on the window revile. Where the window board would normally go. Do we start with a cut tile or an uncut tile ? Do we stagger or not ? My gut feeling is a cut none staggered tile so it appears to wrap around. See photo.
Thanks in anticipation . Chris.
Reply to Bevelled Metro Tiles..... Trims, edges and window reveals. in the DIY Tiling Forum area at TilersForums.com
