Discuss Travertine : can/should it be laid flat? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
A
AllyCa
I've had a travertine floor fitted in my new kitchen. Many of the tiles are flat and level against each other with nice light grouting between. But several have a significant difference between the levels, so you can see and feel the side of the tile. When you stand at the kitchen door and look over the whole floor you don't only see the grouting between the tiles - there are several spots where it's dark because you're looking at the side of the tile. The fitter says this is normal/to be expected with natural stone tiles like this. Am I being too fussy? Would really appreciate an idea of what is best (or even, acceptable) practice when it comes to the leveling of a natural stone floor. And what would be the solution to get it looking right, if this isn't it...
Tile Shop
Are you able to provide images?
I would say they need to be flat, but a height difference of 1mm is allowed by British Standards for a grout width of 6mm or less. (2mm for over 6mm width)
If the tiles are Honed and filled, they should be manufactured to be of a uniform thickness, so a difference of height may then have been caused by inconsistent adhesive beds, or an unlevel floor (which should have been fixed before laying anything).
If the tiles are tumbled Travertine, there may be a very slight difference in thickness's, but this can normally be overcome by adjusting the bed depth or grading the tiles before fixing.
A
AllyCa
Thank you so much for this. It is filled and honed Travertine, from Topps Tiles. I've attached some photos and would be interested in your thoughts. Presumably the British Standards allowance is for health & safety (eg trip hazard) rather than what looks right aesthetically?
A
AllyCa
Here is the first image, more to follow
gamma38
1,058
Bedford
I would tell your general builder that he has ruined your floor and he needs to reimburse you for the cost to rectify it. That is crap, plain and simple.
To be fair though, why did you employ a general builder to tile? He may be a good builder but that doesn't mean he can tile, which he obviously can't.
What a shame:(
sadly it's a common theme on tile forums though. fixing stone and tile to a high standard is a specialist skill.
Fixing tile and stone to a 'general' standard, well that's what you have here.
I'm still amazed though that some people view that kind of standard as acceptable!
How about grinding and polishing rather than a full rip out? Unless of course it's been spot fixed...
A
AllyCa
Thank you to everyone for all your comments. This has been very useful, and helped in my conversations with the builder. Just another quick question, if you have time : if there was any other solution for making this good which didn't involve lifting the whole floor and starting again, what would you suggest? Someone has mentioned grinding and polishing. Is there anything else? I'm just interested in knowing all the options available. Many thanks!
H
hmtiling
What a shame:(
If it's been spot fixed and still that bad then the guy needs shooting!
H
hmtiling
I think they're your 2 options
gamma38
1,058
Bedford
Your only option really is to rip it up and start again. Unfortunately this puts all the stress your way. You have to either pay for it all again with someone else doing the job. Or go down the route of getting money out of your builder. I would say your builder would be reluctant to cough up a load of money. I wouldn't grind it down, as said above.
Reply to Travertine : can/should it be laid flat? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
  • Question
