Discuss Help! in the DIY Tiling Forum area at TilersForums.com.
scotmk
I know I am.not a professional and I know you guys don't like spot fixing but I have used spot fixing and they are on solid they are not coming off for anything, albeit mine were a lot closer to the wall and used more dabs and used a good quality adhesive. The plasterboard and skim looks bare and not treated/prepared so the adhesive will not stick to it. This for me would give been the problem.
When I tiled my other bathroom being more of an amuter then, I missed a chunk of wall and it was not prepared properly and the tiles fell off after curing just like the above picture. When I corrected the wall and fixed the tile again the same way it was solid and still is 4 years on.
Spot fixing can work if (and it's a big if) the depth of the spots isn't too great and if overall coverage is high. Because it leads to lazy fixing and shortcuts on preparation, it's not a recognised or recommended method. Yours is one of the worst examples I've seen and invariably the rest will fail in time. My advice would be that it should all be removed, any pva on the plaster should come off too.
julie bw
Thanks for that advice. The adhesive used also came off in one piece not on either wall or tile!
For it to snap off porcelain as cleanly as that, the adhesive was probably not suitable for porcelain.
Combing adhesive onto the walls at the proper depth, back-skimming the tiles to fill the waffles and fixing properly into a suitable adhesive would give the best possible bond.
They should be fixed so strongly that the plaster skim on the walls would pull off first!
julie bw
Exactly what I thought.that the tiles had pulled the plaster off the wall with them,but obviously not.as for the adhesive.I had bought Bal adhesive originally but he didn't want to use it and bought his own flexifit powder. At one point he ran out and I went to get more but it didn't say it was for porcelain so I questioned him and he said he would guarantee it as he uses it on every job!
J Sid
Good to see he has given you his guarantee, will have no problem getting him back to put it up again ;)
Bill
Ok thanks.should the tiler have known about this if he was a decent tiler.
So get the plasterer back.............Probably not able to.
I am not defending the tiler but sometimes customers think it is a quick job to tile a bathroom - well it is if everything is done well. Many times the customer would not be prepared to pay for the cost of new walls that are true and plumb. Sometimes the tiler is between a rock and a hard place. This is also the tile shop problem as they should ask what the tiles are being fixed to and advise accordingly.
julie bw
Another point - in the original post you mention that the wall was only skimmed - is that correct as the clinker/building block should ideally have an undercoat on - that being a plaster coat or a sand and cement render before the finish coat. Please clarify because if it is just a finish coat the moisture absorption may be too high for any other coatings.
If the tiler would have said the tiles won't go on that wall or they need this and that doing I'd have gone with it so the job is done correctly even if it is a bit more expensive.with regards to that wall it is clinker block which had been mortared the skimmed as far as I can remember.
Dan
Admin
5,040
1,323
Staffordshire, UK
Reply to Help! in the DIY Tiling Forum area at TilersForums.com
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
  • Question
