Discuss Help! in the DIY Tiling Forum area at TilersForums.com.
White Room
Any advice please. I had porcelain tiles put in my bathroom 12 months ago. Gradually on one wall they have started to lift and are rocking when touched. The wall behind these tiles is clinker block that has been skimmed with plaster. Can anybody advise me why this has happened and will the tiles be able to be put back on again. thanks
Skimmed with a single plaster coat or a two part plaster system ?
julie bw
What he should have done was use an appropriate sealer usually the same make as the adhesive manufacturer which absorbs into the plaster.
Pva tends to sit on the plaster surface and can soften even when it has dried when moisture from the adhesive soaks in to the surface.
Ok.thanks so much for your advice.will mention this next week to him.he's already said that he wants another £200 to re tile the wall
I wouldn't mind but I didn't employ him in the first place it was the plumber who did!
Dave
Subscribed
389,894
1,000,000
Co.Durham
I think he has spot fixed and will know when they come off next week. As for the pva why shouldnt he have used it and what should he have done. Thanks
When using a cement based adhesive onto a gypsum background , you have to use an appropriate acrylic primer etc as this helps prevent a reaction between the adhesive and the gypsum backing
Using PVA simply seals the surface and :
A.. Does not prevent ettringnite formation
B.. It as mentioned above forms a skin which when wet , say by the adhesive bedding , becomes live and breaks the bond of the adhesive from the backing.
Spot fixing isn't correct application but not a deffo reason for tiles to debond , my money is on the PVA priming.
julie bw
Pictures when can please.......
Hi. One tile was taken off today.it was smashed so didn't have pic of it but here is the wall behind.it has been spot fixed if u can see on pic.also ll ok at the gap between the wall and other tiles.isnt this wrong? In one part you can push the measure 25 inches under the tiles before it hits any adhesive! The pics show the marks on the plaster off adhesive, the gaps between wall and tiles to the left, right and above the tile.what do you advise.should the whole wall be taken off and redone. There was also a radiator on the wall and the plumber has said it was because of that. A a a aah!
Reply to Help! in the DIY Tiling Forum area at TilersForums.com
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
  • Question
