Discuss Tile Straight Onto This? in the DIY Tiling Forum area at TilersForums.com.
mickp
I am about to embark on tiling my bathroom floor and looking for a bit of advice. I have tiled a couple of floors before but always onto concrete and have gathered that upstairs floors need some different considerations. The house was built in 2013. The floor is solid and even. I am not 100% sure of what the floor is actually boarded with. It seems to be chipboard but with some kind of coating. I am wondering if I can tile straight onto this or whether or not I need to use backer board first. I would prefer not to as I could do without the additional thickness but above all I want to do the best possible job and have no issues with it. I feel like I could be answering my own question there. I was thinking to use keraflex maxi s1 adhesive to allow for some additional movement of the floor. Is this necessary?
I have searched a bit on the forum and it seems that most people are using backer boards in the bathroom when going onto ply or chipboard. The thing that is making me doubt if I need to is the coating on my floor (see below). I Plan to use 12mm thick quartz tiles and the bathroom is 4sqm.
Thanks in advance
Mick
mickp
Thanks both for the replies. I was pretty much coming to that same conclusion but it is nice to hear it from someone who actually knows. Backer board it is then.
Would I still need to use the s1 adhesive or would standard keraflex be better. I'm staying away from rapid set this time as my skills are not up to working fast. I threw as much away as I used on my last job (30sqm) and spent forever cleaning my tools :(
Thanks again
Mick
mickp
Thanks for all the info. I think playing it safe and taking the hit on the extra 6mm added by backer board seems the sensible option for me. I'm definitely not a pro and rubber crumb s2 is a different language to me so I definately shouldn't be messing with it. Even if I say so myself my last job ended up looking great but it took me forever and I threw away more adhesive the I used so I definately need to take the path of least resistance.
Cheers
Mick
Reply to Tile Straight Onto This? in the DIY Tiling Forum area at TilersForums.com
  • Question
Bathroom floor. I would be grateful for advice on how to prepare my bathroom sub floor ready for tiling.I have removed the floor boards and plan to lay 18mm WBP plywood.The question is, what...
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which is very thick concrete. He wants electric underfloor heating but I'm concerned he'll lose too much...
Hello I plan to tile our bathroom with 60x60 cm tiles (8 mm thick) and the shower (because of the slope from all sides) will be done with mosaic tiles (5x5 cm). After researching I came to the...
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
