Currently reading:
wet room tiler recommendations please
Discuss wet room tiler recommendations please in the Tanking and Wetrooms area at TilersForums.com.
Cold Eagle
hi there,
i was not sure if i should put this in find a tiler section as i was more hoping the regulars might be able to point me in the right direction to ensure i do not end up with a cowboy. i have seen numerous post saying it is such as shame people do not ask on here first as it would have avoided all the problems.
i have a downstairs wet room that needs a floor to enable to to be used (again). i understand my only options are the 'useless' vinyl or tile and these seem to be costing roughly the same which surprised me. It is nigh impossible to find someone (local) to provide a quote let alone actually turn up at the agreed time to do so. So I am turning to the sister forums for help; as you have all been so kind in the past when I have asked for help and I need this job doing right.
I am looking for a reliable tiler(s) who will be able to provide a quote for tiling a wet room bathroom floor. This was previously covered in the vinyl type stuff (cant recall the proper name atm) however this was letting water through when we purchased the house. I have since pulled this up and allowed the room to dry. I believe the current drain is the vinyl type but understand that this can be converted to take a tile floor by changing the top bit.
Is there a regular I can PM my location to for contact? or is my best (and most reliable) option to pop it in the thread?
Oh and if there are any other wet room floor alternatives I would be grateful if you could suggest them. I had considered attempting this myself however given it is a ground floor wet room i think i would be out of my depth as i have never tiled before!
many thanks
Reply to wet room tiler recommendations please in the Tanking and Wetrooms area at TilersForums.com
Hi all. Just wanting some advice and wondering what the pros in here are using nowadays for cutting large format porc? Ive been relatively lucky up until recently and been able to cut most of...
Hi all, I'm hoping you can help with some feedback, please My parents are currently having a new bathroom installed, all stripped back to bare walls and floor. The fitter has done/hasn't done...
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
