Discuss tiling over a hard foam with pipes layed inside???? in the UK Tiling Forum area at TilersForums.com.
Arn Wheeler
hi guys,
ive had a look at a job recently tiling a bathroom floor. the plumbers have layed like a preformed hard foam with plastic poly pipes running through it.
basically im looking on any advice i can get as ive never tiled over this before and im wondering if i can use nicobond plastic ply layed over the top then tiles over or would it be finr to tile over it as it is and use a single part flexi white adheive for floor and possible flexi grout as its chipboard under the foam profile.
if i can i will try and upload a video of it as i walked it through.
any advice would be great??
cheers guys
Points
563
liverpool
Hi arn I have tiled a few of these floor and I tiled straight on top of the boards and pipe and I have never had any problems with them. one thing I would say tho is the plumber said the boards didn't need screwing or sticking down but you could actually see them moving as you walked on them so I made him stick and screw them down or I wouldn't do it as I could nt guarantee that would it wouldn't come up I used weber low dust flexi adhesive good luck mate
The Legend; Phil Hobson RIP
As above for me, I would insist on glue and screw for the baords, also Mapei recommend slc to encapsulate pipes.:thumbsup:
Reply to tiling over a hard foam with pipes layed inside???? in the UK Tiling Forum area at TilersForums.com
