Currently reading:
Tile levelling system for 300mm floor tiles
Discuss Tile levelling system for 300mm floor tiles in the Canada Tile Advice area at TilersForums.com.
I need to lay some tiles on a bathroom floor area of about 2m by 2.7m.
The tiles are 300mm square porcelain. The floor is 18mm plywood, marmox, heating mat and SLC.
Despite my best efforts, the floor is sloping slightly. It's about 7mm out over the 2m width.
Can I use a floor levelling system when the slopes as above? Will it take the slope out of the floor.
Which system is recommended for someone who hasn't used one before? I've been looking at the Gemini Easy Level system.
WetSaw
I think you've completely misunderstood what levelling systems do, that is get the tiles level with each other. They shouldn't be needed with small tiles and would probably make the job harder. If the floor is flat not level and you are not bothered about it sloping just tile it. Otherwise as above, prime again and another layer of SLC to get it level.
Thanks for replies.
I realise that the levelling system is to avoid lippage between the tiles and not designed to fix the slope.
I was more wondering if such a system can still prevent lippage when used on a floor sloping as described.
The last time I tiled a floor, the tiles had a slight rounded edge so any slight lippage wasn't really noticeable (to me). The tiles this time have a sharp edge. I wanted to use the levelling system this time because I think any lippage will be much more visible.
I do have some Mapei renovation screed but believe I can't feather edge it?
Reply to Tile levelling system for 300mm floor tiles in the Canada Tile Advice area at TilersForums.com
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
