Discuss Repairing large (130mm) hole in tile in the DIY Tiling Forum area at TilersForums.com.
Stygma
Points
11
New Zealand
I had some work done leaving an approximately 130mm diameter hole in the floor & tile where pipes previously came through. Wondering if it would be best to replace the entire tile or just patch it with a piece of tile?
I know normally it would be replace the entire tile as this would theoretically look best in most cases, but in this instance the replacement tile would not match the existing tiles and would need to be cut to size as the tile is an unusual size (330x330mm) so am not sure what is actually likely to look best considering this.
Reply to Repairing large (130mm) hole in tile in the DIY Tiling Forum area at TilersForums.com
