Discuss Removal of Impact Adhesive from Ceramic Floor Tile Surface in the The Welcome Forum area at TilersForums.com.
Points
88
UK
Hello, I'm looking for some advice quite urgently. To explain: I recently pulled up some faux-laminate flooring strips that had been stuck down over a lovely old ceramic tiled floor. This floor covering must have been stuck down with an industrial strength impact adhesive and, as such, has left a very sticky residue on the surface of the ceramic floor tiles. I have tried various method and different chemicals to try and remove this horrible stuff (heatgun & scraper, acetone, decapant, hydrochloric acid, WD40, petrol) - plus several strong washes - but the stickiness is still there on the tile surface. I actually like the original tiles and I am keen to restore them as they are otherwise intact. Can anyone recommend a method and/or product that can easily remove this sticky impact-adhesive residue from the surface my ceramic floor tiles ?
Many thanks in anticipation,
Keith
Points
88
UK
Hi Tony, thanks for your reply. No, it’s a clear residue on the tile surfaces which makes me think à very strong impact adhesive, maybe factory applied to the self-adhesive floor covering which I pulled up. Keith
Boggs
Points
1,118
Uk
You could give Ct-1 Multi Solve a go.
Lou
Admin
Staff member
Points
1,473
Staffordshire
Welcome, sorry about your sticky situation! Have you got any further along sorting it out?
Reply to Removal of Impact Adhesive from Ceramic Floor Tile Surface in the The Welcome Forum area at TilersForums.com
