Discuss Recent full refurb in the UK Tiling Forum area at TilersForums.com.
craig t
Recent full re furb i completed,
On this project we had to completely revamp a tired bathroom with original fixtures and fittings from the 1950s.
We had to update existing lead work, replace all copper pipes and reduce unnecessary pipes in the loft to update the plumbing system ready for new fixtures and fittings.
All walls were stripped back to brick/block and re boarded with 12.5mm plasterboard to ensure the perfect surface to tile on.
As the room was 2m long with the bath being 1.7m a bulkhead was built to allow an exact fit for the bath and also to allow pipework to be concealed.
In addition the bath panel was tiled flush to the edge of the bath to add to the design. All pipework was boxed in and a heated chrome towel rail was fitted.
The left hand wall was tiled in grey/green ceramic and matching grout to stand out from the marfil tiles and grout on the other 3 walls. A recessed mirror was fitted centrally on the feature wall at a height suited to customers needs.
The main feature in the project was that despite having a combi boiler the customer indicated that it took several minutes for warm water to reach the bathroom. We installed a digital shower with an external switch. This enabled the client to turn the shower on and wait till the water reached the desired temperature before entering the shower.
craig t
Customer was a retired architect so the standard of workmanship had to be very high. Have received 2 more leads form this job which was nice. I also received a 200 quid tip which was good as I had already talked them around to overspending there budget by 1500 quid to ensure the best finish possible.
The only down side was not tiling the floor customers supplied vinyl and beading which were not to my taste but the rest of the job got a big thumbs up from all parties:8:
craig t
Starting from scratch dos'nt that make work so much easier:thumbsup:
I only do jobs now where its a full rip out and begin again, had enough of bad walls and other trades, I project manage the pieces of the job we cant do so the buck stops with us, the plus side is the we always get it right and the customers appreciate all the effort demolishing and then rebuilding their bathroom!
Reply to Recent full refurb in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
