wight19
Hi, I am planning an exterior tiled patio, this is already laid concrete (cured for about a year). We have bought a quantity of porcelain tiles (30cm by 30 cm). What sort of adhesive is best for these?
I have sealed the concreate with 1:5 PVA, although it was not particularly absorbent.
I intend to place these tiles onto a solid bed of between 5mm and 10mm Could I use standard cement mortar mix, with a waterproof additive? Or should I use a Unibond waterproof 'tile on floor' type of ahesive? this states bed depth of 3mm - 5mm? What may happen if I were to exceed this depth?
The patio area drains well and the edges of the tiled area will be waterproof flexible filler to allow for any movement and the grout will also be waterproof.
Thanks for your help, Tony.
