Discuss No more ply - Priming in the Canada Tile Advice area at TilersForums.com.
Uk
Hi,
I'm installing my bathroom. I've used No More Ply around the shower area walls and on the whole floor. The instructions say to prime it with their SBR primer to waterproof the boards.
I have bought Mapei Rapid Set Flexi to tile the walls and floor. The instructions on this say I must use Mapei Primer G. Will I be ok to just use the No More Ply SBR instead?
Also, outside of the shower enclosure my walls are just skimmed plasterboard (my tiles are only 10cm x 20cm). I'm half tiling and half painting these walls. Should I use Mapei Primer G here or, again, will the SBR be ok?
Uk
Hi, thanks for your replies.
I'm confused now because I checked this before with No More Ply and they said...
"Thank you for the further information. You do not need to tank over NoMorePly®, as it is waterproof (providing the joints are sealed with Megastrength and it’s primed with NoMorePly® primer as per instructions)."
I got confused when the Mapei Addy instructions said I must use Mapei Primer G, as I think it's impossible to follow both sets of instructions?
F
Flintstone
It’s a bit mis leading imo. There system involves gluing the joints to seal them. As you said, they say that simply using sbr on the face will make it water proof. I don’t beleive it, after asking the rep about it, he said they have done a Ribena test on it. Primed it and put a droplet of Ribena on and left it 24 hours and it didn’t soak in so it must be water proof :eek:
Reply to No more ply - Priming in the Canada Tile Advice area at TilersForums.com
  • Question
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei suggested using Primer G before tiling with keraflex maxi s1. They did not recommend using SBR for some...
Hi all, I'm hoping you can help with some feedback, please My parents are currently having a new bathroom installed, all stripped back to bare walls and floor. The fitter has done/hasn't done...
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
