Discuss Mapei renovation screed primer in the Tile Adhesive / Grout Advice area at TilersForums.com.
Points
38
Preston
Hey guys
I've got a new, tampered concrete floor.
Not sure if I need primer before applying Mapei Renovation Screed
If yes, I've got a ton of SBR. Will this work?
The screed will be containing UFH pipes.
ES
I
Italy
Q
Qwerty
As above, it's always best to follow manufacturers instructions and use the same primers. You could phone Mapei technical dept tomorrow and ask your question but I'm pretty sure they will stick to the primers listed above. They may possibly say that Primer G will suffice but to be honest your SBR will work and plenty here would use it with no issues. It does also depend if it is the correct type of SBR
Points
38
Preston
Thanks guys
Yeah I had a good search of the forum and have seen plenty of people use SBR but just wanted to make sure as its my first time.
Its ever build brand Bonding SBR
One Day
I'd be happy using SBR. Diluted probably 3:1 as everbuild is quite diluted anyway.
Make sure you're not bonding dust though - vaccuum first.
Wayne Brown
Points
548
Norfolk
Like this ? 100mm celotex laid on the slab a polythene dpm laid on top the celotex and cut and taped expansion foam strip added all around the perimeter of the room and structures this one will have a flow screed pumped in to a 90mm thickness , please explain how your floor is being done em I missing something?
Reply to Mapei renovation screed primer in the Tile Adhesive / Grout Advice area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
