Discuss Kitchen Splash back with metros - setting out for trim in the Canada Tile Advice area at TilersForums.com.
acaciaguy
Points
558
Warwickshire
Hello all,
I have a job this week doing a kitchen splash back and window reveal. The wall behind hob has a boxed in section which means extra cutting. I had originally planned and customer agreed that they wanted mitred externals. They have now changed their mind and want to use white round edged trim. Fair enough their choice. The tiles are white metros with a bevel. Around the window reveal and the boxing in would it be best to ensure that where tile meets trim that it is a cut edge with the thickest part of tile body so that there is a uniform edge between trim rather than some edges onto trim being bevelled. Tiles are 7mm at their thickest. Trim will be 8mm. I don't do many bevelled tiles with trim so wanted to see how others would approach so I get the best result. Many thanks
Andy Allen
Points
1,318
Gloucester
Use 8mm trim, I go cut edge to the trim with half tiles, With full tiles put the bevel edge to the trim...
acaciaguy
Points
558
Warwickshire
Super thank you for that. Until I set out tomorrow afternoon I won't know for sure but my plan is to treat the area between the box and the corner as one wall, it is about 2/3 of the area of the kitchen hob / extractor wall and has the extractor in that area. Then see if I can "bend" around the box and finish the other 3rd. If this is going to look bad Im going to treat each of the 3 sides individually and then finish of the 3rd. The window reveal wall should be sound Im just hoping that the distance from worktop to window sill is good to me. Yours look great behind the sink. I hope mine is 2 tiles or less not just a bit more lol
Wesley
Points
273
East Anglia
Hello AA,
Just a quick question about finishing off when using tile trim. In the photo above : where the piece of vertical tile trim is cut off level with top of tile, do you generally use (white) silicone and “fill in / smooth off” top of trim to “blend in” as best you can ?, or do u have a practised technique for finishing off ?. Thanks Wesley
Reply to Kitchen Splash back with metros - setting out for trim in the Canada Tile Advice area at TilersForums.com
