Discuss Hairline Fracture in Wall Tiles - What could be the cause? in the Canada Tile Advice area at TilersForums.com.
N
nalla
Hi lads,
Just been back to a wet room job i done over a year ago and two of the wall tiles (opposite wall to the shower) going into the corner have slight crack lines on them, you can see them but can't feel any lipage, (i used webber low dust rsf) I will replace them no problem and i gather the reason for this is slight wall movement???? also any other tilers on here get simular problems???? Thanks in advance for any replies.
SJPurdy
pictures would be useful.
What is the structure of the wall, and what type of tile?
Is there a joint in the boarding behind the tile?
When did the cracks occur?
They shouldn't just crack for no reason and unless you understand the reason then it may happen again when you have replaced them
N
nalla
The cracks are just a sraight line but not following a brick patten or any patten. (sorry i've no photo's
J Sid
I think the only way to tell what's going on is to strip wall back and investigate, taking photos as you go
N
nalla
Yes i will take the tiles off and have a look at the wall, come to think of it the cracks are more like crazy paving if anything.
J Sid
yes seen it before in Villeroy and Boch ceramic high gloss glaze. Give it a few more weeks in the steamy environment of a shower room and the cracks will get worse as moisture gets into the biscuit though the face. I had the tiles replaced foc.
N
nalla
If i remember correctly, there was some emulsion on some parts of the wall, as for the bed depth it was my half round medium trowel. (approw 5-6mm)
Time's Ran Out
The cracks are straight line but like crazy paving!
There was some emulsion on the walls.
Up against it a bit trying to give advice to be honest but when you take the offending tiles of and give some photos and tile type you may get better input.
Reply to Hairline Fracture in Wall Tiles - What could be the cause? in the Canada Tile Advice area at TilersForums.com
