Discuss Full Bathroom "project" in the DIY Tiling Forum area at TilersForums.com.
F
Falcone83
Hi,
I am new to the site and have started refurbishing my bathroom. I have only started ripping the old one out and have posted some pics of the job so far. there's pics of how it was previously also.
I have done a bit of tiling before (my kitchen floor, splashback, my mums hall floor and kitchen floor and one other job) and although I have never done a full bathroom before I am quite confident of doing this. I have a friend who is a joiner and another who is a plumber who said they would help when I need them.
I plan on posting the progress on here and I appreciate all help given.
I started taking the tiles off the wall and fond another set of tiles underneath which was a pain but the top layer of tiles had been dot and dabbed on so came off ok with a gentle but firm hit with a hammer.
I had to take the external wall back to the brick as it will need re plastered. I am reluctant to rip the bath and shower out until this is done as I cant go too much further until then. I have a downstairs toilet so these have been removed upstairs.
White Room
Ok thanks, I will look into this rather than plaster.
I initially thought about strapping the back wall and putting plasterboard but when my friend who is a plasterer suggested just plastering it I thought that would be ok
If you done a solid plaster on those blocks there's a 90% chance the plaster will crack in some way, if you plasterboard any movement will not follow thru to the tiles.
F
Falcone83
What type of tiles/materials do you intend on using?
Are you aware of the necessity to tank?
Could you move the shower to the opposite flat end of the bath wall?
All these things considered will help you leave a proper job :)
We've not went as far as picking the tiles yet but I understand what adhesive I need to use on the walls and floors and I will be picking ceramic tiles but not sure on size.
We are going to get a shower cubicle, there is an electric shower already on the back wall and I will need to have the the floor boards lifted to re plumb the cubicle.
I thought tanking was only required when installing a Wetroom?
L
LM
You need to tank any wet area, even inside a shower tray or above a bath and in turn use powdered adhesives. Tubbed adhesive will not cure when used with a tanking system.
Plaster board in these areas is ok if correctly tanked, but for the extra few pound you'd be better going with a tile backer board. If you run with ceramic tiles then there won't be a weight issue with plaster board. Ask your mate the plumber to install the shower tray in conjunction with Classi or Aqua seal, then follow the tanking kit instructions regarding application and simply over lap the Classi seal with a band of tanking tape, then also tape down the internal corner and you'll have a fail safe shower. Also make sure you over board the floor boards with something like hardie backer.
F
Falcone83
Thanks for the info, we were thinking about maybe using wet wall for the shower area as it's easier to keep clean. Still undecided though. If I go with tile I will be sure to tank it.
I am definitely using hardiebacker over the floorboards. The floor is sound throughout, no movement in any area.
I'm assuming the shower cubicle is fit first and then I install backer board around it and then tile?
Reply to Full Bathroom "project" in the DIY Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Question
Bathroom floor. I would be grateful for advice on how to prepare my bathroom sub floor ready for tiling.I have removed the floor boards and plan to lay 18mm WBP plywood.The question is, what...
  • Question
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
  • Question
I am looking for 1 wickes Mississippi grey tile - damaged 1 tile in my kitchen and they have been discontinued 😭😭 looked everywhere online - wondered if anyone could help😞
Hello, I am about to waterproof an existing shower after taking out all of the old tiles and old mud waterproofing. From what I see there is an existing drainage. The idea is to clean everything...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
