Discuss Foam boad vs cement board in the Canada Tile Advice area at TilersForums.com.
Points
98
Yorkshire
What do you pros on here use most then?
Ragrdless of customers budget and you choose msterials
Xps foam.boards like jackoboard,marmox weidi etc
Or
Cement boards lile hardie, no.more ply etc with tanking where applicable
Or
Plasterboard just to throw it in there.tanking where needs be.
Dont know how you would put this thing to a vote maybe admin coould help out with that one :).
Dumbo
Horses for courses .
Hardie 6mm timber overlay without ufh
With ufh 10 mm Jacko etc .
Walls jackoboard , easy cut,carry, and handle and if it needs waterproofing only need to do joints and fixings there for not affecting weight carrying capacity .
Hardie tanked has it's weight carry capacity reduced , this needs to be tanked all over as it is water tolerant not waterproof
jobdone
Points
533
Chobham
Most installs I use plaster board and tank the wet areas. I find it's easier to dry line with the larger boards.
As I do full installs floors are 25mm ply with detria. Or 18mm ply and 6mm Jacko board
widler
Points
1,328
England
9 out of 10 wall jobs are plasterboard, floors i vary from form boards or cement.
My go too cenent boards are hardie, I don’t like NMP, too smooth for my liking
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
Or
Or
You can create a poll as you create a new thread if you wish but I think you get the gist from the response already maybe.
I'd be happy to see a poll created though.
I haven't seen a real one on this forum software yet.
On one
Not having seen the Bal Board yet, what advantage would this type of board have over cement boards, plasterboards or polystyrene boards?
F
Flintstone
I've used BAL board, it is similar to a cement board but it's made of magnesium, it's very light and can cut with a Stanley and can cut curves etc.its got a lot of fibres in. Not sure on its price but I would happily use it.
F
Flintstone
It's smaller than Hardie, 600x1200, deffinately more user friendly, can't fault it really.
Reply to Foam boad vs cement board in the Canada Tile Advice area at TilersForums.com
