Currently reading:
Floor prep advice
Discuss Floor prep advice in the Canada Tile Advice area at TilersForums.com.
Hi there, I have a shop floor to price up. It's about 50m2, currently vinyl and they want it tiling. It's a suspended floor with a little bounce here and there so I'm wondering which prep option to go for. I could possibly ply over for some added rigidity then ditra over that? The main problem there is that part of the floor is concrete so how would the ply fix to that area? And what thickness ply required if using Ditra? Thanks in advance for any help.
Personally I'd rip up the vinyl but 18mm ply will do ya and Ur concrete area drill and plug the floor before laying trowel little adhesive underneath the ply and then begin to screw in place
Keogh Tiling
CJ
1,088
Somerset
Thank you. I presume you mean 6mm cement board? Does this offer the same rigidity as 18mm ply though?
If the floor is “THAT“ bad, then you would be better off strengthening the floor first.
ie......lift floorboards, If need be, add noggins.
replace with 18 or 22mm ply, overboard that with 6mm cement board, then self level screeded area up to the cement board.
Reply to Floor prep advice in the Canada Tile Advice area at TilersForums.com
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
