- 1
- 513
i have a feature wall to do in an en-suite using these tiles
broken link removed
They are 800 sq, 15mm deep and weigh 40kg psm. The wall was skim plastered on breeze block, I have battened it with 40mm timber at 300 intervals using rawlplugs and will board with 12.5 mm marmox, which will be as flat as possible. Manufacturer only specifies cementitious adhesive, ntg more specific, I was planning to use mapei Adesilex P9 which is non rapidset to give me time for adjustments. Any advice on adhesive and tile cutter I should be hiring?
broken link removed
