Discuss extruded foam insulation board in the Australia Tiling Forum area at TilersForums.com.
The Legend; Phil Hobson RIP
has anyone tiled directly onto this foam backer? no cement coating, just foam with electric ufh mat?
can't say I fancy risking it.:nonod:
Just Rizzle
don't think I would fancy tiling to it ether as its got nothing to make the adhesive bind to and with ufh when the addy drys out what is stoping it from debounding.
J Sid
Yes done it twice now, and its been fine.
One a conservative floor about 15m2.
The other a large kitchen floor, 38 m2 with electric underfloor heating. This one I really don't want to do. After a long phone call to the supplier I followed they instructions and all was good. Have been back to this job to do another room and the floor look perfect.
I was supplied with a primer to be used on both sides, sticking down and tiling side. They also supplied Mapei adhesive. No self leveling over wires, straight tiling on wires.
Sean SML Tiling
I may be wrong but would mapei eco prime grip stick to the foam as it sticks to pretty much everything.
Rookery
I used some uncoated insulation board once, supplied by the customer. Horrible stuff. It didn't feel as rigid as the coated stuff.
U
Uheat - Keith
We have sold the same one for the last 9 years, over 200000 boards to date.
Make sure it is 'floor grade' insulation boards.
We always say on our quotation, "Onto a load bearing base the ..mm insulation board will need an overall extra spare depth of ..mm: ..mm board with 2mm powdered flexible tile adhesive under the boards to fix.
Flexible self-leveling compound over UFH system.
A powdered flexible tile adhesive is used to fix the floor finish."
Warm regards,
Reply to extruded foam insulation board in the Australia Tiling Forum area at TilersForums.com
A little help guys. I've been asked to price 71sqm of limestone flooring. My issue is this...
