Discuss Exterior Tiling in the Tile Adhesive / Grout Advice area at TilersForums.com.
A
antded
Yes I did check. Basically its not suited for areas where it will be exposed to standing water i.e. puddles, end of fall etc. Ok if getting covered.
J Sid
Tilemaster done it again.....another product that performs where other's won't go. ;)
I was thinking more along the lines of an outside area that's sheltered
@widler, which obviously this is not!
And if the edges of the path are not totally sealed then it'll suffer moisture ingress, don't you agree?
Levelflex is not designed to withstand that.
widler
1,328
England
I was thinking more on the lines of
' what in the gods do you think he is going to cover a outside path with, carpet ' :)
Reply to Exterior Tiling in the Tile Adhesive / Grout Advice area at TilersForums.com
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are...
