Discuss Correct dilution for MApei Primer G on cement render? in the Tile Adhesive / Grout Advice area at TilersForums.com.
What is the correct dilution for primer G on cement render? (the render has some SBR already mixed in and has totally cured/ dried)
The Mapei pdf does not give an exact figure but says 1:1 to 1:3 depending on absorbency. Preumably the more absorbent the more you dilute?
How can I tell if it needs more thinning when it is applied?
I'm thinking 1:1?
The adhesive is bagged and the tiles porcelain.
Reply to Correct dilution for MApei Primer G on cement render? in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
