Currently reading:
Commissioning under floor heating
Discuss Commissioning under floor heating in the Canada Tile Advice area at TilersForums.com.
Good evening. Could someone kindly give me an idea of the process of commissioning water fed under floor heating which has been set in sand and cement screed. It’s fully dried and is ready to be commissioned record I may it and tile it.
I’ve got some knowledge but it would be great to gain some more knowledge. Least of all so I can show the builder in black and white the process
thanks in advance
Starting at its lowest setting of ambient temp approx 15°
Start to increase temp to max at a rate of 5° every two days until maximum is reached.
Hold for 48hrs and decrease till back at ambient temp at the same rate as you took it up.
it takes a couple of weeks normally.
Then leave off for 24hrs before tiling.
Others say 5° a day, from what I’ve learnt over the years, a rate of 2.5° a day is preferred.
There will always be different opinions on a matter like this, but as an average, it seems to be the safest route.
Ajax123
1,213
Lincolnshire
Pretty much as 3fall says above. However you will not be able to start as low as 15C as the temperature needs to be set at the manifold and the room stats over ridden somthat theh dont cut in and out in order to give a constant flow temperature. Your manifold is likely to start at either 25 or 35C. I would normally say max 5 degrees per day after 3 days but with sand cement slower is better so not going to argue with 2.5C per day. Once the process is complete it can take up to 48 hours for the screed to properly cool down.
Once complete a moisture Test is recommended prior to priming and tiling.
Reply to Commissioning under floor heating in the Canada Tile Advice area at TilersForums.com
