Currently reading:
Classi-seal
Discuss Classi-seal in the UK Tiling Forum area at TilersForums.com.
davy_G
Its very common on sites over here, getting more common in domestic applications as well. Its better in my opinion than plumber applied silicone that wont stick to the dusty wall. However most of them have them too tight around the corners and i have to cut the seal (thus rendering it useless & i fill it with silicone instead) to get a tile to fit right in. So as Dave says if fitted correctly they seem fine.
Better just tanking the whole thing in my opinion though.
H
hillhead
Your right there Davy,plenty of it here indeed and too tight in the corners,
i always cut it too when needed and silicon the gap to wall and even stick the seal tight to wall,the tanking kits tape has to drop into corner too,awkward when the seal is cut,lol.good old silicon(mapesil)
C
C McC
The classi products are the best waterproofing products on the market in my opinion. I recently renovated my bathroom with the help of a friend who is a plumber/bathroom fitter. He recommended using a Classi Bathroom Waterproofing Kit for fitting a bath with an overhead shower and it was great. Really straightforward to install with clear instructions and my bathroom has been 100% waterproof since I fitted it! Think they even have a kit for wateproofing a wetroom
Great products in my opinion.
Andy Allen
1,318
Gloucester
Blunt Tool
I have used this a few times on shower trays after being recommended on here from guys who create excellent work and I respect very much and by no means weekend warriors and it hasn’t been thick, obtrusive away from wall at the corner or any other negative it’s useless even tho I’ve never used it throw away comments! Kerdi is not the only solution for total waterproof guaranteed installation, there are lots and always comes down to the installers experience and confidence to install correctly. It is a very good option if used and installed correctly like any good product!
L
LM
I insist on them on large new build housing sites in conjunction with tanking.
If the shower tray/bath are of good quality and square vertically i.e: the upstand and top are 90 degrees rather than sloped from a cross section point of view then the Classi seal installed correctly is no obstruction at all, it's only about 1-1.5mm thick.
If when installing it the plumbers silicone it to the wall and have it nipped around the corner of the tray properly and not stretched it, then held the corner in place with a piece of wood scrwed to the wall until the silicone sets, when we come to tank it it's not in the way what so ever, it's a clean 90 degree and vertical internal angle.
I do agree that there are other options out there but I haven't found any that are more cost effective when tanking large volumes of new houses with a restrictive cost to build.
Have any of you guys had experience with the black adhesive on the seal creeping under the silicone seal, between tray and tile? happened to me 3 times now
Reply to Classi-seal in the UK Tiling Forum area at TilersForums.com
Hi all, I'm hoping you can help with some feedback, please My parents are currently having a new bathroom installed, all stripped back to bare walls and floor. The fitter has done/hasn't done...
  • Sticky
